04_6.0
My friend has a 92 idi and yesterday he called me upset that he now has milky oil. Crazy thing is he just drove it (8 days ago) 700 miles to florida and picked up a used rzr. Nothing seemed out of place and nothing went wrong. He changed his oil system and had 1-2 gallons of water come out. He said that he can top off the radiator wait 10-15 minutes and open the oil drain plug again and have the same amount of water come out of the oil pan!!! Is there something simple seems like a lot of coolant for cavitation or a blown headgasket. He has ran sca in it since about 2009 and has put 50-60k on the truck since then. I Gave him the advice that you all gave me and he is going to do a compression test and check for obvious things. He is suppossed to start an account here and do some reading. Just wanted him to be able to get a headstart on things.
We pulled the glow plugs after toping off the radiator. Spun it over 4 revolutions and no water anywhere. Compression check came out great all cylinders were between 415-460. Any other suggestions? Still have the same problem can top off radiator and can watch the water trickle out the oil pan. Water pump bolts possibly?
