loss of oil pressure
Moosebob
West Bloomfield, MI
No.. Thats kind of low at the turbo. What line do you have feeding the turbo. Sounds like it may be plugged with something.
It's the stock metal line, 1/4" I believe. I'm figuring one of the stupid brass compression sleeves turned sideways in the oil line or more than likely something went bad inside the turbo. The tailpipe is blacker and sootier than it normally is.
smokerd
victoria/bc
Thanks...good forum here. Now I'll stop worrying about my 'dummy gauge' centerting on the 'O' in normal and just pull the dipstick every few mornings.
'93 7.3 IDIT still ticking along at 394K.
nostrokes
Colorado
Check it hot not cold, that's the way the manual says. Run it to operating temp, let it sit 10 minutes then check it. The oil will "expand" a little.
I don't know how accurate it is, but if I want to check my oil cold, I consider "full" to be about halfway up the cross hatch. I'll let the oil level get a little lower than the "add" mark, but try to keep it no more than half way up. If it's over full (hot) this way, I doubt that it would be very much.
Alleycat
