Looking at this 96 F250 4wd 5spd
madpogue
Madison, WI USA
And the fuel gauge didn't read right, it ran all of the way up to the peg and stayed there.
That would be a break in the circuit between the gauge and the sender. Possibly the selector valve; the gauge circuit runs through it. Did this happen on both tanks?
direwulf23
Botkingburg (NCen), AR
I switched to the other tank. I've no idea if there is any fuel in the tank but I know I did, personally, put 5 gallons into the front tank as that was the tank it was on. When I switched to the rear tank the gauge went to empty but it never sputtered or quit running. I only left it there long enough for the gauge to stop moving as I was worried it might be empty and figured it could pick up trash.
To sum up, I switched to the rear rank and the gauge went to empty
direwulf23
That's what I expected.
Is there anything to consider about the hard starting. The wife said when he was starting it sparingly that he often hard a time getting it started and would use ether. That certainly concerns me more.
lindstromjd
Black Sheep
West Des Moines, IA
Nah, I wouldn't worry about it. He probably had a hard time starting it because of his fuel leaks, and that mechanical pump doesn't do you any favors when it comes to re-priming the fuel bowl.
direwulf23
That's something I thought (hoped) it might be.
At this point I'm not eliminating the truck for purchase just trying to get an idea of what I might be getting into while fixing it right. There doesn't "seem" to be anything major wrong with it.
Anybody have any links to installing an electrical fuel pump?
I plan on going the mark fuga route. Fuel Pump and Filter Package: http://youtu.be/ku15mGaBSPw
He's a member on psn, but I'm banned so I can't link you to him on there. Lol
I think Lindstrom has some of his older stuff.
But I don't know if he got around to installing it yet. Lol
I definitely like the idea of a stock super duty pump, as you can find one at any parts store.
lindstromjd
Black Sheep
West Des Moines, IA
Yeah, I have Mark Fuga's second version of his e-fuel kit. The only extra thing you need to buy with his kit is the filter setup and fuel pump. Everything else is included and bolt-on ready. Still not installed on my truck yet, but I'm going to use a stock Super Duty pump.
Oh, and yes, your IDI sending unit will work in the PSD. They're the exact same thing.
