Location of Windshield Washer Lines
Chemgrad
NC
I just bought a used 2008 Dodge Ram 2500 and noticed that the windshield washer wasn't working and after a little searching found that the line from the pump is disconnected and wanted to know if anyone knew how the lines are run on this truck? I have one long hose running from the pump and ending in a connector but don't see another hose to connect it into. Any help would be greatly appreciated. Thanks,
Matthew
Chemgrad
NC
Alright well for anyone else who runs into this issue I found the the lines. There's one that runs from the driver's side reservoir and one that runs into the cowling where the washer nozzles are located. On the truck we just purchased it was disconnected for some reason over by the passenger side fender underneath the air filter. After I got the line hooked up and everything back in place I realized that I think the line is supposed to go along the top channel by the radiator, sorry guys not a pro so I don't know all the correct terms. I ran it in front of the radiator but don't think it will be an issue. Just thought I would put this up there in case anyone else ran into this issue as I couldn't find this info when I looked.
IDIBronco86
