tbryanh
I had to crack an injector line to get my 1989 E350 van to start after it sat overnight. I then found a big leak in the rubber return line hose near the transmission bell housing, so I replaced the hose. I am wondering if there are any other rubber return line hoses that might need to be replaced?
The rubber hose near the bell housing connects to steel tubing at the frame, so I aim assuming steel tubing runs along the frame to the fuel tanks, but I bet there are rubber hoses that connect the steel tubing to the tank selector valve. I also suspect there are rubber hoses that connect the the selector valve to the tanks.
I recently replaced the return lines that go to the injectors using a kit I purchase, so I am assuming all the return lines near the engine have been changed, but I am not sure about that.
Any help other than recommending that I stick a sock filled with cat litter in the return lines to absorb any leaking fuel will be appreciated.
Thanks.
Thanks.
