LLY injectors
nitrohogg
nitro ******
outside chicago
is there anyone out there that can rebuild these things???? every avenue I turned down has brought me to a dead end. had injectors tested by midwest fuel injection just to find out parts are not available to rebuild them, has anyone had any luck getting these repaired?
HDpullingpower
Chestertown MD
If I am not mistaken, I believe the injectors are under warranty until at least 100K, if not 200K. You may want to contact your dealer.
nitrohogg
nitro ******
outside chicago
I'm waiting to hear from them now......got a friend who knows somebody at a dealership. you would think somebody would be able to work on these things, finding out now that I should have numbered each injector so I could put them back in the same hole and that the computer has to be reprogrammed and that each injector is flow tested and that number has to be programmed to whatever cylinder it goes into!
