Light Switch melted
Belle Fourche, SD
I towed a 16 Ft trailer 2000 miles this weekend to haul my new dodge back its an 01 3500. In my 94 I started smelling something funny like electronics burning. :dunnoSo i pulled over and well my light switch became a molten chunk of plastic. So i managed to get lights on by wiring some other things together. It has trailer relays and has been pulling stuff for quite a while before i owned it. What to do? Has anyone else had this happen?
Whit
lost in Why-homing
its a common thing with these believe it or not................you prolly had it dimmed just a touch withour realizing it, thats when they generate the most heat in the reostat...............best to keep it as bright as it goes just b4 yer dome light comes on
1991 F350 Crew
Northern Connecticut
The Fords have a problem with melting plugs. If you look up Running Light Relay Modification. I think it will put you on the right track. It'll take a little load off of your headlight switch. You'll have to figure out how to make it work on your Dodge though.
GaryB
