Leaking windshield
Weldingman
Pennsylvania
You are aware there are two type clips for the trim?
There are 16 that go up both sides and across the top. Then 9 as I remember that go across the bottom, they are a longer type. The others are small and square.
I had to locate them as the shop was out of both styles.
I might have bought them from Bronco Grave Yard.
Did a search and found them.
If you drill holes to use the Pop Rivets, good idea to seal the holes or a rust issue or leak will start.
There are the little button thingys the clips attach to.
The is the kit I bought … hopefully it’s the correct one.
m2rtin
