longhorn795
alright i gotta find where this oil leek is coming from this time, but first off about a month ago the ebv actuator rod started leaking down in behind the engine so without looking further into it we thought it was a rear main so we ended up jerking the tranny out putting a new seal in and getting rid of the dmf while at it,so put that all back together and still was leaking then i saw that the ebv actuator was pouring oil out of it so deleted all that, and now stil a oil leak right on the back of the engine, everything is dry in the valley everything is good on top, could it be the oil pan gasket?, ive had the tranny off 2 i dont know if that would make a diffrence in anything though, the back of the oil pan is wet and coming onto the flywheel cover, i hope it sure isnt that dam rear main ughhhhh
