i have a hard start first thing in the morning, usually 2 cycles of the glow plugs and several cranks before it will fire up, when it does it revs up without me ever touching the go pedal. have 142,000 on the original injectors and lines. the pump was replaced at about 70,000. if the general feeling is bad injectors what all else needs to be replaced. i've had this engine since it was new so i am sure of the service records on it, performance is ok not super but satisfactory. what do you guys think?
