Leaking Fuel Lines
schoelta
One of the braided fuel lines from the frame rail to the engine decided to start leaking. Does anyone know where I can get replacements? Ford says they are discontinued, and no where in the country, and I can't find anything in aftermarket. Any suggestions?
Thanks
riff raff has them too
are you sure its the line itself, and not just an o-ring?
schoelta
Thanks for the FORD part numbers. The dealer found them, and I have them ordered. Same price as the ones on EBay.
It looks like it's leaking from where the fitting connects to the hose. That's why I wanted to replace the hose, just to play it safe.
Any thing over 10 yrs. old, most Stealerships don't want anything to do with them, there to damn lazy or incompetent to look up for part numbers, like you just found out when you gave them a PN.
If it's just leaking at the fittings, there is an O'ring in them, .50 cents would fix it.
