rckslash2010
I noticed yesterday that my truck was leaking around the oil filter. I tightened it by hand, and called it good. Well, today I changed the oil and filter, and other stuff. I tightened it as tight as I could by hand, and took it for a test run. After I got home I noticed that it was leaking again, I reached up there and it was as tight as I could get it by hand. I know that by saying hand tight doesn't really specify any kind of torque, but I'm pretty strong, and on all the gas engines I've ever done had never leaked. Is it any different with diesel's? Should I get a filter wrench and snug it up some more, apparently so. I checked and the old oring came off with the old filter, so that's not the problem. I can't tell if oil is leaking above it and falling on to the filter or not, but when I reach up there with my fingers, I don't get any oil on them.
