Kent Moore injection line clamp j33300-25a
FarmerFrank
Blairsville, Pa
Anyone know where I can get a new clamp for my timing meter? Went to time someone else truck a couple weeks ago, pulled out my timing meter and the line clamp was gone!!!
Can not find that thing for the life of me. Searched online and eBay and didn't come up with much.
If anyone has one they'd sell let me know.
Thanks!
I can't say for certain it would be compatible, however it does the same thing...
Look up tinytach
http://www.tinytach.com/
They may have a replacement clamp
Just sayin...or PM Gary he may as well...who knows what Mr.fixall has
Sorry do not have spares. Kent Moore is the only place I know has everything for these meters. Figure around $65.00 for the clamp. The wire harness is another $175.00 and the mag probe is another $375.00 last I knew of. They also sell the luminosity probes around $400.00 plus and another $200.00 or so for the harness. I have plenty of lumi probes and harness's.
i saw one on e-gay 2 days ago, cant find it now..
but i did find a vacuum pump i needed!
FarmerFrank
Blairsville, Pa
What do you search for on eBay to find one?? I thought I tried everything.
Gary what's the contact info for kent Moore?
Clb
Another old truck
nannyfornia
Bosch owns em now
Service and repair( ask me how I know)
1800-344-4013
i search e-bay for so many things.
from Alpha one to Singer, i tried to find it, no luck....
i knew i shoulda posted it when i saw it, my bad
Last time I used kent moore I had to go thru SPX Corp. That place I contacted was in Fountain Valley Ca.
Clb
Another old truck
nannyfornia
Yea spx is now owned thru bosch tools.
Re kent moore.....
Ya send yer stuff to bosch who sends it to a third party repair shop.
Mine has been gone for 6+ weeks so far, via that ph#.
You can call www.tooldiscounter.com @ 888-663-8665, they advertise the Quartz clamp pickup the 6.0mm and 6.5mm line size as separate part. I couldn't find them, you'll have to call.
FarmerFrank
Blairsville, Pa
Check the last truck you timed! It's probably still on the line.
I did :/ that's the worst part. After searching for a while through the shop I was like duh! It's probably still on my truck. Nope. Not in the valley pan or down in the core support either. It's been months since I had my meter out so who knows where it could be.
If the meter is the J33300 it has a pocket in the lid where things can hide. Also sometimes things can get under the panel and hide back there too. Simple.. Just remove the 4 screws in the panel and lift it off.
ntjapkes
