BleednBlue68
Ford Country!
They must have kept it in a garage if it had 386k on it. Looks emaculate! Hows the interior?
hopefully that water didnt play havoc with any other internals.
Yeah, I think you could have skipped pulling it and just filled it with fresh oil with maybe 2 quarts replaced with ATF or Marvel, run it a bit and then change with new oil again.
Only in the south can you get a truck that looks that new that's that worn out.
Does anyone have the wiring harness that hooks to the drivers side injectors? This bit was cutoff for some dumba$$ reason. I need it to go all the way back to the main harness. I would appreciate it, the salvage yards around here are quite bare of these trucks.
The threads for the glow plugs is 10x1.25 MM. You can actually use 1/8" pipe , it will go in about 4-5 threads and will not harm the block threads, even tho I have a fitting for compression check I use the pipe for an extension, works great.
