ISO shim plate between 7.3idi and trans
ISPKI
Granby CT
Hey guys, im doing a tranny swap in my 94 f250, from e4od to zf5 but my setup didnt have the shim plate between the tranny and engine. I need it to act as a drill pattern guide to get my truck up and running. Not sure what they are worth but i only need it temporarily as a guide so im hoping we can work something out
all 7.3 IDI's in fords use the adapter plate, you should have it.
laserjock
Almost there...
If you have the trans out, 2 bolts takes it off the block if memory serves. They may be behind the flywheel if it's installed.
ISPKI
Granby CT
They must use one farmer Frank. Ive read the write ups on this forum that say the shim plate is sandwiched between the trans and engine
laserjock
Almost there...
He says he needs a drill pattern so i assumed he was drilling a 460 trans.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
No shim plates. Just the adapter plate. It's and inch thick. Just unbolt it from the block. Simple as hell
FarmerFrank
Blairsville, Pa
I've been wrong before but I've also had enough of these engines out that I can say it's not a shim plate. It's 1" of steel that adapts the block to the bell housing.
If your trans is out then pull off your flex plate or flywheel and remove the 2 1/2" bolts from the back. Pry it off and bolt it to your trans. Drill holes accordingly.
ISPKI
Granby CT
Ya, i was confused. When i had the writeup it called it a shim plate and when i googled that it showed me something totally different. Im all set, drilled the holes today.
