ISO Fummmins Custom Motor Mounts
LewCain
I have a 2012 Ford F250 4x4 with the Ford 6.7 diesel, I also have a 2018 Dodge 2500 4x4 MegaCab with a Cummins 6.7 diesel. I plan to take the motor/trans/transfer case from the Dodge and convert it to my 2012 Ford. I am looking for motor mounts for the Cummins conversion. Anybody make these? I can only find them thru the 2011 Fords.
If you are wondering why, it is quite simple: I got bad fuel and it fragged the Ford HP pump, polluted the rails and injectors. The best quote I received to repair it was $8,500 which is more then I feel it is worth. So I decided to build my dream truck- 2012 F250 Lariat 4x4 body, Cummins 6.7 motor/fuel system and later is an Allison 1000 tranny. The MegaCab has 108 miles on it and the passenger side got t-boned, so I bought it for $6,500.
ColLonewolf
Eustis, Fl
I admit I am getting old, but it seems I recall something about using 460 motor mounts upside down. Might be just a bit off my rocker.
Grey Wolf
Acton, Ca
http://www.cumminsdieselrepowers.com/
olsen726
