I'm thinking you would have been better to buy a trans cold carrier electric from Genlightening .... He is a member here and has a very good deal on those pumps. The pull suction from anywhere..... Next time you see a semi truck pulling a refer trailer look at the refrigeration unit way up top in the front. Then look back under the trailer where the spare tire is. Next to the spare is the diesel fuel tank for the refrig unit....
Thats about a 40 foot pull and up around an 11ft lift to the units... That pump can pull some fuel a long ways.... They have a prefilter and I have never seen one burn out or go bad... I did run a holley red for years but their quality has slipped some... I burned up two of them and I know my tanks are clean... The electric motors brush contacts and armetures fail terribley.... No repair parts for that either..... The motor shafts don't have seals on them either...
