Working in the HVAC industry for 13 years I have seen a lot of pumps, but never seen a voit. I mainly deal with Robinair, J/B, yellow jacket etc. Those are some of the names we use in the trades. There are a couple others also, but those come to mind now. As stated earlier, 20" vac is not enough. I am sure 27 would work, but with a 6 cfm dual stage pump you can pull to 29.9 in about 15 minutes. A vacumm pump is one of THE most used, and important tools in my arsenal. I live and die by it basically. I personally would never consider and old refrig compressor. Yes they can pull into a vacumm, but they are not staged for a deep vacumm, and working on many refer systems commercially, they don't pull usually past about 22". Most of them have worn vallves by the time the units are decomissioned, and then they pull even less vacumm. I have pulled compressors before that did run, and the capacity was so low, that they wouldn't even pull a 5" vacumm. Buy a good pump one time in your life, it will work on your system, I use my pump on automotive R12 systems regularly. There is really not a need for an automotive machine if you know how to work the manifold set correctly. BTW, get a good manifold set to that will last you to, get a set of Richie yellow jackets. Sure I have four sets, but the first manifold set I bought back in 1996 still works for me today. I never get rid of anything like that. If you have questions let me know, I'll steer you right if I can, or at least try to anyway.
