Good video, Al. The original write-up was excellent, and now you've topped it off with the video which has further explanation.
A couple point and comments.
I remember that we once had a thread in which we debated at great length the terminology of width, thickness, and all other measurements of a dime, both US and Canadian. According the standard we set at that time, and which you followed above, I used the wrong term. You've illustrated the differences very well.
In your video you stressed that the timing gear was NOT turning in conjunction with the IP as you were turning it. I would stress equally that this was the case purely because you had removed the 5/16th bolts which normally lock them together. With those bolts in place the IP and the timing gear ARE locked together and will rotate in conjunction with each other, as a single unit. However, when they are locked together, the innards of the IP can still turn/rotate. This is, in effect, what you are doing when you turn/twist the IP to adjust and/or align the timing marks. You're changing the relationship of the innards of the IP and the casing of the IP, causing the fuel pulse to change slightly.
That wasn't all that clear, was it?
The other thing I'd like to mention, though it bears only peripherally, is that rotating the IP becomes harder once the hard lines are connected to the injectors. I had to fight mine a bit that way.
Again, a very good job, Al.
