"International truck" 6.9L cooling system capacity?
mrroboto1975
Outskirts of hell
Have a 1986 International S1600 6.9L. Looking for someone that has an old book that lists the total cooling system capacity. It is NOT the same as a Ford (GVWR and therefore radiator is much larger). And I don't need to know how much antifreeze to buy to fill it up.... I am flushing to clear water, and need to know what half of the total capacity is to get a 50 / 50 mix.
Sorry I don't have the information you want but I know if you drain and count the gallons drained out.. you will know the proper amount. Please remember to drain BOTH sides of the block.
riphip
Memphis, TN.
Just use the 50/50 pre-mix and count how many it takes to fill. Don't forget to reinstall block plugs back
Nanohawk
