International / super duty turbo install
RKOCH
Fellow Oil Burner
Yorktown, Virginia
Ohh I built the pump that is on it now. I can make 3 lanes traffic and the sun go out. I will tell you all a secert a DB2 pump is only capable of producing 25 to 27 HP per cyl actual engine HP within emision specs, even turning that screw as far as it can go. Now you can swap parts from a DB4 which is capable of 40 plus Hp per cyl. Larger barrel valve, larger Dia Delivery valves ( BTW this is what you are adjusting the travel on when you turn the fuel screw) and up the transfer pump pressure. and you can make a screamer. I have done alot with the fuel system just trying to run with the PSD crowed @ the pulls. I got that pump pusing all the fuel it physically can now. Pumping the propane now pretty hard to match the nitrous shot.
69dieselfreak
well that nice
rimrock arizona
thanks for that piece of info ;Sweet
what does that DB4 pump come off of
RKOCH
Fellow Oil Burner
Yorktown, Virginia
I ordered new parts but they were put on stationary power equipment and marine apps. They were used on John Deere I know some perkins. The pump itself will not bolt to an IH. IH has it's own mounting pattern. A DB4 is more like a 6.2 GM mounting.
RKOCH
Fellow Oil Burner
Yorktown, Virginia
Correct, same mounting as a DB4 though. The DB4 has 4 delivery pistons instead of 2 that is what the 2 or 4 means.
REM70
Staff online
