RKOCH
Fellow Oil Burner
Ok several people have asked me about how I got a superduty/ International turbo on my IDI's....
Well The units I use are GT-40 Garrett turbos (comp AR .58 / turbine .95) OE on First and Next Genration DT466 mechanical motors, DT466E, T444E/ powerstroke ( ford has it's own flange mounts for the piping as you will see. All mine have come from T444E and DT 466 E engines. This one is from a DT. It is a Non-Wastgated free spooling unit. These were only used on the first gen powerstroke. Boost levels have never been a problem as 15 psi is the highest I ever saw on this motor pulling a mountain with a 45 foot trailer. Average boost is 3 to 7 psi under normal conditions. Now you have to build your own petistal mount but was very simple and presure hat still pretty simple. A simple oil drain tube and some oil lube tubing Aeroquip to the rescue.
This was taken before the intercooler and ram air so you can see the thing. None of that bolt on flange crap simple hose and clamp on intake and v band exhaust. 3.5 inch outlet and works great if you have time and the skills to fabricate than this is for you.
