plywood
Recovered N/A
So I have this 94 factory turbo core that was supposed to have a knock.
I have the oil pan off and there are some pieces in there that look a bit like pieces of spark plug (oh sorry is that cussing) feeler gauge.
I'm wondering if it isn't a thrust washer/bearing that blew.
I did see what looked to be little tiny pieces of brass in the turbo oil port, I'm guessing that took the last of the turbo.
So far I see one injector was leaking combustion fairly good and the tip is in the head, and other than that the top of the heads anyway look great. Maybe that injector took a rod bearing out?
Right now it's hanging so I can't take the heads off easily.
Anyway, just tring to figure out what to do with this thing.
Thanks
Thanks
