Not sure what TF some of you are saying but last I heard a lifter bleedijg DOWN caused a lifter CLATTER/TICK...
A lifter NOT bleeding down correctly...AKA PUMPED UP or LIFTER JACKING is what would cause the HUFF out intake....
one way keeps valve open longer.....the other shorter....
In theory running seafoam or what ever should be fine 1 can in oil run about 500 miles n drain IIRC my conversation w them. This Could maybe clean out a deposit blocking the lifter and allowing it to function correctly.
More than likely the guide is worn and that is the culprit and yes it can be intermittent....however if it is a guide it likely WONT improve with age and wear if not corrected.
JM7.3CW Eh!....but *** do I know
