mohavewolfpup
Diesel Wolf Puppy
Pardon the long thread title!
I won a prized diesel instrument cluster everyone wants for the 6.9 off ebay earlier this month (late birthday present if you will). Now, in a strange fashion, it's time for a birthday present for everyone to enjoy with the info I found pertaining to it, (Hope this isn't out there already!) so pull up your chair and enjoy...
Love to dismantle stuff, so that is why this is apart. Want to paint all the gauge needles up and have it looking nice since these clusters are not the easiest to remove due to the speedometer cable (Try removing one, then one out of a PT Cruiser and tell me which is easier! done both here)![LMAO LOL LOL](/styles/default/xenforo/smilies/lol.gif)
Here's the cluster after I received it:
Marked on the top of it (by the person who removed it) it says 1986 F350 on it
It's made up of 6 gauges, the face plate with all the information printed on it (diesel fuel only, etc) a enclosure to house all the gauges, the clear plastic bezel with trip odometer button, a printed circuit board and the following: 6 screws to retain the clear bezel on, 10 light bulb sockets, 5 blue covers to change the light bulbs and diffuse them, 12 speed nuts to hold the gauges down from behind and make contact with the printed circuit board, and finally... 2 bolts for the speedometer along with a gasket to isolate it from the enclosure and seal it some. Whew!
Now some dismantling photos:
And finally, the best for last.. and why you may have clicked on this thread!
Removing the tach from the back has the following cast into it:
Interesting, time for google shall we?
"The Faria Corporation has been manufacturing gauges in Uncasville, CT for more than 50 years (established in 1956) and has grown from a company that primarily produced tachometers for the marine and auto industries to one that today offers a multitude of analog and digital engine monitoring instrumentation to a wide range of global markets.
Over the years, the company has transitioned from an electric and mechanical gauge manufacturer to an ISO9001 electronic hardware and software design company with in-house pick and place assembly lines for surface mount technology (SMT) circuitry."
Here is their website:
http://www.faria-instruments.com/
And some even more interesting stuff pop ups on their website:
Industrial Tachs: http://faria-instruments.com/products.php?calledGauge=1_tach
Industrial Tachs with Hourmeter: http://faria-instruments.com/products.php?calledGauge=1_tachHr
And finally:
Click onto this link: http://faria-instruments.com/styles.php Then on the coral one, click view. You'll be presented with 4000 rpm tach choices.
I know it's a 4500 rpm tach I have, but that's obviously a danger zone reading. Maybe something out of these can work for others being the "OEM" supplier for ford back in the 80's?
I hope in some way that assists with the mystery of the tachometer on these. I'll see about emailing the company and see if they have any knowledge still kicking around about them, maybe even if they can be remade, stuff like that.
Keep a eye out in this thread, i'm going to paint the needles, get led's installed and post more photos of that plus the end result of it hooked up.
And in closing, here is a list of all fordpart numbers I can find cast/printed into everything above:
Fuel Gauge: EOTF-9306 E1TF
Oil Pressure Gauge: E1TF E4T-9AA
Battery Gauge: E1TF EOTF-10671
Water Temp Gauge: E1TF EOTF-10971
Faria Tachometer: E6TF-17360-EA Also: 6G15 And: FQC 5 (Unlike the others above, the Faria one has it's numbers printed/silk screened? on it rather then cast. I am 99% sure I read them right. It's very faint purple ink for the main number. Others I included just in case in helps, suspect the Last one is a quality control number...)
Front of tachometer: E5TF-17B316-A
Speedometer: E1TF-17265 (2179/80-5) 2293 On Front
Instrument Bezel (Diesel Fuel Only,Fuel,Oil,Temp,Charge,Tach,Speedometer, Top row of lights): EOTF-10894-BB
Gauge Housing: E2TF-10848-AA (CAV 2)
Clear Instrument Bezel W/Trip Odometer: $P2 EOTF-10B885BA
Printed Circuit Board: A E1TF-10C956-B (Q633460686) <--- Possibly the circuit board serial number unique to it? Added anyway)
It's interesting to see the different beginning letters/numbers (EO,E1,E6,E2) Wonder what it means? Different codes for the aftermarket/in house makers of the products?
And that's all folks. Only stuff not in the parts # list above is the screws, speedometer rubber gasket, speed nuts, light sockets/blue lenses (you can find those very easily in dennis carpenter or other sites)
Enjoy!
edit: possible to move to the tech section if good enough? I thought the moderators would choose what to put in the tech section like some forums i've been on!
And finally:
Enjoy!
