installing brake controller need help fast
mustangmatt89
Deale, Md
I need to get my brake controller wired up in my 93 f250 as soon as possible. I found the plug under the dash, a 4 wire plug that has a red, blue, green, and white. What does what is what I need to know. Thanks Matt
EMD_DRIVER
Say what?!?!
Beaufort, SC
You are goin to need the pigtail that plugs into you factory harness. Then you hard splice the pigtail to your brake controller. Here is what you are looking for http://www.drawtite-hitches.com/veh...eavy+Duty&style=All+Models+Including+SuperCab
If you dont have a 7 way RV plug you will need one of those as well
Since my 93 only had a four-pin connector, I was unable to find the appropriate connector. I bought one of the SD six-pin plugs and used my dremel tool, to convert it to the four-pin version. I did have to move one wire, but that was easy!
