jdkline
Hey guys. I spent 4 hours getting my electric pump installed. Wire to pump to switch to fuse to battery. Problem is, it didn't prime up at first and like an idiot I started the truck, cause I wasn't sure if it was running or not. The truck drained the fuel filter and then quit running. Worked with teh pump some more and it did start pumping, as a result, I found the initial problem that caused my leakdown. Since last year I replaced my fuel pump to filter head hard line with a hose, teh hose had a small hole in it. This became redaily apparent only with teh electric pumps pressure on the line, then it was squirting liek crazy out of that hole, looks like a result of vibration and/or a losing encounter with a V-belt. After I got fuel pressure on teh supply side, I could nopt get fuel to teh injectors, so I'm hoping I haven't inadvertently toasted the injector pump. It just doesn't want to push fuel. Is this massive airlock even with the electric pump, or bigger problems? The other concern is, since I have a hgood light and left teh doors open, plus the pump was running, and a lot of cranking etc, I wonder if the IP is not getting enough voltage to inject. FSS clicks but haven't checked for adaequet voltage. i was just so angry after all that work, I had to walk away from it, that and I have to be at work in teh morning. If anyone has any ideas, please chime in,
J.D.
J.D.
