Injectors
smookthis05
Delaware
How hard is it to switch the nozzles out off your stock injectors for a set of performance ones????? Are there any specialty tools required or is it pretty straight forward?? Or is it not worth the hassel and just buying performance injectors is better bang for the buck???
kwcrusader
florida
I pulled a few of my injectors a while back, It took a while but it's not rocket science. I had to clean them up so I took them totally apart. It's pretty easy to do. They called for a special tool to pull the injector out but I didn't need it. Just pry them out with a pry bar but (be careful). I'm sure if you Google it you'll find the removal procedure.
placidoert
