Injector replacement
Lunchbox1373
South Dakota
I have a 2004 F-350 (build date 04/04) with a bad #4 injector. I want to get all my parts together so I can get everything done in a weekend. Will this engine have dummy plugs and stand pipes? What else should I do while I'm in there? Thanks in advance.
Where is your icp sensor? That will tell you.
Dummy plugs, stand pipes, and stc if so equipped.
I recommend warren diesel injectors.
Lunchbox1373
South Dakota
It's on the passenger valve cover. So dummy plugs, stand pipes, and stc fitting. Is there any thing else I should be looking for?
bismic1
Texas
fyi - none of the 04's had the failure prone stc fitting. Only 05 and up.
bismic1
Texas
There is a lot of confusion on that. I think that it came mainly from a DieselTechRon video. He stated that the 04.5 and up had the STC fitting. One mistake out of all his incredible help - not bad!!
IDIBronco86
