slvrwrx
yeah, son
Does anyone have a write up on how to properly replace an injection pump without messing up the timing? Ive only found out how to improperly remove the ip..
Thanks a lot guys. So when installing the working ip.. will the dowel cause It to only go on one way? Or is there a possibility of installing 180* off or something like that? And also, guessing about the timing wont cause a runaway situation would It? I read the article and I don't know where I could get my truck static timed.. is it doable at home? Will the engine run at all?
if the gear wasn't moved in the R&R procedure of the pump, you won't have a problem. Only way you can move the gear is by removing the four bolts and pulling the cover.Is there a way I could have installed the ip with the timing so far off I'm going to hurt the engine? There's a little line stamped on the ip and I am assuming that is the tdc mark.. I just don't want to mess anything up by running it with the timing severely off. It should be pretty close tho..
I think maybe the timing is off I have no idea where to take it to be timed.. I might look into doing it myself.
I am in Modesto, Ca. I have the necessary meter/light and have done a couple already. PM me and we might be able to get together to get it timed.
While we are at it, you can see what is needed and how to do it. It isn't that hard.
