injection pump not pumping
idijack
Alamogordo NM
:mad: I took a good running 7.3 out of 90 f450 and put it in a 89 f350. The pump is getting fuel and is filling up but wont pump to the injectors. Will the pump pump with the top off ? I think the solenoid is working it did in the other truck. What is wrong?
Don't take the solenoid cover off just yet, check the fuel solenoid by removing the front wire with the key on engine off. You should hear a click by pulling the wire off and back on several times. Check for 12 VDC on that wire before doing that, or run a jumper from battery to the solenoid and do that. Clicking tells you the solenoid is good.
Pretty vague info your providing...how about details and lots of them about what's going on whats been done was it a known working unit previously how you swapped it etc.
Not enough info to provide a good diagnosis!
Al
idijack
Alamogordo NM
it ran great in the other truck now the injection pump wont pump anything to the injectors I ve changed the seliniod cover and no change. the pickup pump is working fine .
