seawalkersee
It needs a turbo...
So, some of you know I rebuilt my IDI in my Bronco. Have had it running for a while now but the milage is down from prior to the rebuild. Also, with the cam, ported heads, baby moose, and I am sure I am missing a few other things, the power band has raised it's self a bit. It is a slug off of the line. But wiht both of those it may be timing.
So instead of adding to my old thread, here is the new one...
This thing has power on flat land and upper in the RPM band like you read about. But since it is a stick, I have decided to go without adding the blower. I was chatting up one of the tow truck owners in town the other day that used to live down the street. We got to talking about this and he says, "I have one on the back of the flatbed at the yard. Come and get it..."
Today I went and got it. With the powerstroke turbo, I got the exhaust manifolds, up pipes, stand, down pipe, outlet/inlet hat, IC pipes, and all of the attaching hardware and probably most of, if not all of the clamps.
I also snagged the hydroboost setup. It has a 5 spd in it but it is LOOOOOOOOONG, and I don't think it is a ZF. It also has a PTO on the side. BUT, its 4X2. I think I will go back for it later.
So all of that work got me a siezed up turbo that I shot with some WD40. Took the snails off and it spins now. So, I need a rebuild kit...no biggie.
All of this for the grand total of N O T H I N G.
I have no idea how I am going to plumb the oil to it, but I think I can get it done...I am pretty pumped about this, and never get this lucky.
I will get pix up later.
SWS
SWS
