I-beam Bushing Replacement
mjs2011
Brookings, SD
I believe the cause of all my front end noise is worn bushings on the I-beam anchors. I have not confirmed it yet, and don't plan on going outside and laying under the truck today with all the snow and cold. :mad:
Anyways, when It does warm up, I will investigate further, but I am pretty sure this is my issue.
Watching this video here, http://www.youtube.com/watch?v=evGHZUwnTbo, and It doesn't look too awfully difficult, but I do not know anyone that has the ball joint press that is used.
Has anyone done this job before, or have any words of wisdom?
ah1988ford
florida
All I know is you can rent the press and adapter kit at autozone. I rented it while doing the ball joints on our econoline worked well.
Sycostang67
Scooty Puff Junior
Kuna, ID
I have changed the pivot bushings on two 4x4 trucks and the ball joint press makes things a lot easier. You can rent it at most any auto parts store, I believe it's free at o'reilly's with a deposit.
mjs2011
Brookings, SD
Burning out the old rubber would require the removal of the i-beams though right?
Isn't that a lot of unnecessary work?
mjs2011
Brookings, SD
Ah that makes waaaayyy more sense. I was imagine putting the end of the I beam in a fire or something to burn it out.... Nevermore that.
So the new poly bushings go in without a press?
Sycostang67
Scooty Puff Junior
Kuna, ID
I used energy suspension bushings and they came with new metal sleeves which did need to be pressed in. Once again, the ball joint press made short work of it.
Ruger_556
Ferndale
I pulled the I-beams out when I did mine. Made it so much easier and I just used a shop press to push them out.
