derjackistweg
Great conversations going, and please.... I'm not the only guru here by far! Listen to these other guys as well. A little disagreement helps point out issues that might not otherwise be discussed, as long as its all kept civil. That Banks literature is interesting. What isn't clear, and what they don't tell you is.... did they touch the IP at all when they swapped their turbo on? That's my suspicion. A turbo is good for 50 HP over NA, and the factory turbo offered only 10hp more than NA. This was due more to the calibration of the injection pump then the application of the turbo itself. If Banks swapped their turbo over, there would have been no HP change without turning up the fuel!
I am pretty sure that banks tuned the IP!
There are some interesting interviews with Gale, longer than 30min, in the net. And always Gales leaves no dought that he develops from end to end! otherwise the system leaves potential unused.
e.g. his commends about black smoke- witch is unused/unburned fuel etc.
On the other hand are people saying and reporting that a stock turbo setup can be finetuned up to 220hp at the rear wheel. Not much than a banks.
