HPOP Pressure Readings
TBAR
Texas
Found a good article here that explains my low readings. DUH!!!
Contrary to popular belief, the HP oil reservoir does not store high pressure oil: the oil in the reservoir is at lubrication pressure, 15 to 45(?) PSI , not injection oil pressure (500 to 2700ish PSI.) A more correct term for this reservoir would be HP oil pump reservoir, but everyone seems to leave out the "pump" part, thus leading some people to think the reservoir is holding 3,000 PSI oil.
http://www.diesel-central.com/News/oil_pump.htm
TBAR
JimmyDee
Western Michigan
My EASE Diagnostics software does it right from the OBD II port. Sorry I dont know the other answer.
Jim
Dockboy
Originally posted by Wideopen
So where is the Correct place to measure the HPOP?? On the 7.3??
The easiest place is the forward plug(5/8") on top of the drivers side oil rail;)
TBaR,
You will need a bigger gauge;)
Strokin_A_Duramax
TS Performance Groupie
Kennedyville, MD
It's a bird...It's a plane no...It's Dockboy.....
I saw you go by today.....At least I think.....I heard a screaming powerstroke ;burnout and when I looked outside all I saw was a white streak..... :thumbsup:
Dockboy
Re: It's a bird...It's a plane no...It's Dockboy.....
That WAS me Andy!;burnout :angel: :D
I'll give you a:yell: tomorrow;)
Alleycat
