Diesel JD
I think the main thing NMB2 did that is allowing him to get away with such high boost levels is to overtorque the ARP studs. He'll have to tell you what that value is cause I don't remember. Also for those that have the skills and inclination to do so, I'm beginning to think that turbo mods or an altogether different turbo is going to be the way to go for a high output IDI. It's been said here before but it bears repeating that the stock turbo kits were designed for stock IDIs with the weak 6.9 head bolts and head gasket issues and folks who were maybe not religious gauge watchers. Since we have overcome these issues and thanks to Mel and Ken we can feed these things more fuel a better turbo and/or an IC or water injection to keep the charge air cool is the next step. An IDI at 15-20 psiG of cooled boost would be very different from any stock or simple turbo truck. On the other hand, if killer HP is not what you need the gear spread is probably a really good issue to look into as RLDSL said, the old Semis took care of much bigger loads than any of us will ever haul with less HP than a PSD. For instance I've seen some ATHS member restored B-61 or B-59 Macks running 237 HP NA or 262 turbo Cummins V8s at the same time they did have 15 to 20 forward gear choices to get over the hill. Not sure if those HP numbers were RWHP or at the flywheel.
