how to hook up a tach!??
soot_monster
otterville/missour/65348
im trying to figure out how to hook up a tach on my 91 beast, but cant quite figure it out. anyone out there already hooked one up to an old automatic cummins?
Whit
lost in Why-homing
the transducer bolts around one of the injector lines. Reads the pulses from the pump.
For you first gen owners that don't already have a tach, Here is one for you!
I just talked to the guy from tinytach and he said they are coming out with a new diesel tiny tach that is BACKLIT !!!!!! And instead of the nonreplacable internal battery that can eventually go dead,They say after 5 years, will be a flash memory that requires only vehicle power. Effectivley making the tinytach last as long as the vehicle. They are 1.5" by 3".Here is a link to the site,http://www.tinytach.com/tinytach/diesel.php They do not list this new tach yet on the website. The guy i talked to said to call back in a couple weeks to order one. He said they would be about 20$ more than the current diesel Tinytach, which is priced at 65$. I will definatly be ordering one as soon as i can!
ez
rubberfish
Langley B.C.
Didn't some first gens come pre-wired for a tach?
IIRC there's a harness near the park brake pedal.
I'm not a hundred percent sure though if it pertains to
the 1991 model years or not. You'll have to look into it.
The tach I pulled off the '92 4x4 (Isspro unit) had a magnet on a bracket that was bolted to the oil pan and took it's signal off the crank. worked great when I was running the truck around the block a few times.
Lance
