Arborigine
I am on my first real road trip with the 85. I am towing a one ton camping trailer. Climbing the Grapevine southbound I had to go into 3rd (T-19) and rolled up steadily at 42 MPH. I don't expect it to pull like my dad's Dodge, but that wasn't much of a load. Mileage on one tank comes out at 12.8, rolling with the cruise on at mostly level ground at 62 Mph. Does that seem unreasonable, with timing at 6.8 degrees?
Stopped in middle LA and truck would not start. I still have leaky O-rings at the fuel switchover valve (should be in my mailbox when I return), and I guess it sucked enough air where the lift pump didn't lift. I paid for a taxi ride to Pep Boys and installed an electric pump, it didn't work. I found out it's outlet check valve, not removeable, was stuck, so freed it up with a dentist's pick and then the truck fired right up. Its good to be a mechanic.
