how does this even happen?
those lines are cracks.
the whole damn lowerend is spiderwebbed!
overfueling wouldn't be the cause.
and the color tells me that I didn't overheat it too bad.
but daymn catastrophic failure.
I found the water leak, but didn't go any further,
@Clb was actually the one that found it.
now I wanna tear the rotating assembly out and dig a lill deeper.
Bolt hole filled with oil ,screwed in with impact and cracked? Ive seen it happen, where was the water leak?
cpdenton
Truck needs paint.
Conway AR
Does this engine have a stud girdle that r&d sells? Perhaps something with the fasteners there?
I have R&D's lower stud kit and girdle.
I didn't use the impact on anything on this engine. all done by hand.
didn't have 1 issue either.
maybe it was cracked before I got it?
the water leak was coming from a crack as well, right inbetween 1&3 and 3&5
Did you use the lube on the studs?
I actually just seen talks about a guy using oil on main studs and cracking them.
yep, ARP lube was used.
but like I said, everything was ran down by hand.
That is one pissed block., Now you have a planter. lol
And no I havent checked that bore yet, ill be at work tomorrow and will do it. More free time when I dont have to babysit.
I forgot the forum, but I asked about using the arp lube. Nobody answered me.
But from what they were saying, use nothing on them. Lol
bwahahahaha thatll never happen!
yesterday I had an employee grinding tubes, and didn't even indicate it in the chuck before grinding, and was crying because he couldn't get it to clean up LOL
tubes were .150 OD with a .094 ID SMFH
whos they?
R&D says don't use it.
ARP says using it eliminates retorquing.
Some guys on a forum. Lol
I just can't remember if it was ford idi, psd, or a GM forum.
IMO if the fastener manufacturer specifies to use it, you use it.
don't believe everything you read on the internet? lol
Thanks AL gore. Lol
Can't say I disagree with that. At least a company like arp.
Now motorcraft, GM, etc is a different story.
Holy frijoles Batman! That is wild. For it to be that widespread, it's got to be a systematic error. Since the only thing different about your build is the stud girdle it just about has to be related to that. I don't know how it didn't scatter.
I wasn't nice to this thing either.
the girdle sat nice and flat on the mains.
there was no movement.
I don't think it was the issue, but I could be wrong?
brb5
