Marty... That rusty fuel is not a problem. What your seeing is the fuel running out of the injecter nut and washing out the small rust thats on the line and nut. Thats not in the fuel system. Remember thats leaking out and not in. So slow down about draooping a full tank of fuel and cleaning out a tank. The bottom of your fuel filter has a water in fuel sender. As it fills with water the lite on the dash lites up telling you this. We have a drain under the filter to let out any water too. Sadly your turbo is shot and I would not run that another minute. Its way out of balance and these turbos spin upwards of 120,000 rpm. Thats 2000 rpm per second. Typ4 aka Russ can rebuild that for you better than most shops and he stands behind what he does too.
