Homemade propane injection kits?
ricerocket86
griffin ga
Anybody ever made one or do you just have to buy a $800 kit. I have a 97 and a 2001 Im wanting to do propane on. Any advice?
ricerocket86
griffin ga
Exactly what I needed! Now all I gotta do is figure out how to regulate the solenoid according to throttle position for when Im towing heavy loads. Shouldnt be too hard. THANSK SO MUCH!
Mike
Stroker
Cora
You'll probably want to use your map sensor (boost) to trigger the solenoid..... ;)
ricerocket86
griffin ga
omg. I cant believe I didnt think of that. That would be so much easier and probably safer. Thanks to the both of you.
shvlhead78
St Charles MO
diy propane injection
How would you go about tying in the setup to the map sensor for the triggering purpose.:dunno
Thanks
Shvlhead
weedsabate
Chino, CA
Back in the early 70s I was hauling ammo/explosives out of Tex I was based in Oklahoma City. I had a V8 Mack naturally aspirated and I needed to keep the smoke down I had a nice kit from a propane dealer called Daisy, unfortunatly they are out out business. It had a micro switch at about half trottle, and used very little propane. I had a 5 gal bottle under the sleeper and it lasted a week. I burned about 1 gal propane to 500 miles. not much gain in power but completely removed smoke. Only problem was when I was unloaded I couldn't use the tunnels in NY. Loaded of course I has escorts on bridges, but the fine for getting caught with a bottle in a tunnel was near the moon.......
I can believe if used carefully it should make more power.As you can tell, mine was metered very fine.
rocksam
az
what kind of pressure would be a good starting place "low" is not very informative looks like an adjustable high pressure regulator usually 0 to 15 psi. I can get a low press reg that goes from 10 to 14 in wc normal house pressure
weedsabate
Chino, CA
Rocksam: If I remember correctly, the press was set at 2psi. As that was only a 265 HP engine, I did not have any control over the press as it was preset by mfgr. I only wish I had taken it off the truck when I traded, I would love to play with it now, those days it was my living, so I was cautious about experimenting.
