h2odrx
Anti-O
ok here is a Vacuum pump?
who has the cheapest?
mine is going south and the brakes are getting scary....
FORD wanted $235
FORD wanted $235
I can't answer ur question but what do you mean by scary? I'm having brake issues too. One wheel locks up & others don't feel like they're hitting at all. Major scary sometimes. I've put new shoes & drums in the back with no improvement. Never have brake dust on front wheels either. Cylinders are ggod too. Whats that leave?ok here is a Vacuum pump?
FORD wanted $235
ok so one how do you change oil in a vac pump two why would you put oil in it and three what type of oil can you use???
That just might be my problem..... No Power Brakesit is very worth it to check/change the oil in the vacuum pump! i had one go out from having no oil in it, tore up all the belts. what a pain to drive with no power brakes.... i put a used one on and later found out about the oil. good thing, because i checked the pump and it had no oil in it!
