Fishin76
Ok, My speedo doesn't work, and didn't when I bought the truck. But I'm determined to fix it. So here's what I've done so far:
1. Tested speedo cable.
Result: Spins at both ends. Seems smooth enough.
2. Tested Speedometer:
Result: Speedo registers when I spin the back of it counter clockwise, Got it up to 35 mph with ease.
3. Rigged up new clip to hold cable in to cruise control speed sensor. (old one was missing) I thought this was the problem, but it wasn't..
4. Placed the little rod that goes into the transfer case back in and made sure it was engaged. I tried to spin it, it seemed pretty solid, only a little play when turning it, Less than an 1/8 of a turn. So I figured it was turning when driving.
Next steps?
I think I need to take the driven gear out and look at it, but I'm not sure how to do that. I searched and searched here and FTE and TheDieselStop and could find a definitive post that said how to get the driven gear out. Found lots on how to get the DRIVE gear out of the 1345.0
Thanks in advance.
Next steps?
Thanks in advance.
