7.3IDIDSL
Around a month ago i changed my clutch from the stock DMF to a Southbend SMF.
I havnt even put 1000kms on the truck since i did the clutch due to the gear rattle from the SMF.
Well today on my way home i went to push the clutch in and the first half of the pedal was nothing...so i went to let the clutch out and it only came up about half way. I immediately went to pull over and as i was coming to a stop i went to put the clutch in and when i released the pedal it didnt come back up. So i pull over shut the truck off and go right to the master cylinder which has the fluid right where it should be. I then go back into the truck and push the clutch in and about half way through the travel i felt a slight resistance and then it shot right to the floor. So i pull the clutch back up and check the master cylinder again. Now the fluid is like half of what it should be. So i think maybe the fluid is leaking somewhere under the truck and i climb under to take a look and what do i see....well my slave cylinder is just hanging there under the truck. Im wondering if there is someway i can check the slave to make sure its alright or do i just have to put it back in place? Im thinking the slave probably took a dump on me.
