It very well could be. It could also be that the new injectors are effecting the timing, and causing the issue. That's because they will have higher pop pressures than the old worn out injectors. This is a good thing but you may need to have that engine retimed. Also you'll want to make sure that the idle is 550-750 rpm. Was it ok before you added the new injectors or did the problem start with the new IP?
