Dave 001
The O/D switch and the O/D light are no good on my truck. I want to replace them with a simple push button and an LED mounted in the dash. How can I do this? An E4OD wiring diagram would be great. I have an ATSG service manual but it's just about worthless when it comes to wiring.
I'm assuming the O/D button can be replaced with a momentary "on" push buttom, right? Is the computer looking for a ground signal from the O/D switch? 12 v. positive? or what?
And I'm assuming the wire that would normally turn the O/D light on could be used to turn on a Bosch type replay. And the relay would turn on the LED. Or is the relay not needed? I figure using a relay would be the safest way to prevent from frying the computer. Does the computer provide a ground signal from the O/D light? 12 v. positive? or what?
Thanks for any help.
Dave
Dave
