HELP!! Need axleshaft asap lf
troupp
Roaring Branch, pa
Help I need a Left front axle shaft for my 92 f350 asap, can be either whole shaft or just the outer half. My spindle bearing seized up and ate the shaft up real bad, tore the truck apart to replace the spindle bearing and found the shaft carnage. Now I need the truck and it's 4wd functional. Otherwise i'd throw it together with out the shaft to move it. Thank you in advance for any help I can get --tim
What kind of front axle do you have? Dana 50 IFS?
Probably not. I keep forgetting they did away with IFS somewhere along the way.
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
Ford quit doing IFS under the F350 truck and started putting the D60 under the F350s after mid '85. Mine was manufactured in 01/85 so I got a TTB50 under the front of mine instead of the D60. -cuss
Bradz
