Help me out fellows
Trex
Wampum PA
Dont know where to put this question or any other sites to ask this. I have a 2000 jeep grand cherokee with the quadra track 11 all time 4 wheel drive, troble is it wont go into 4 wheel all time drive. it will work in 4 wheel low but no go in 4 wheel high. ***. Can anyone give me any ideas what to look for?
IHcornbinder
boise, id
Its not designed to. There is a viscus coupling between the front and rear axles. In regualr 4wheel all time it is operated by the computer and you just get what you get. 4low locks the diferential between the front and rear. Im not 100% sure if the crysler computer has a built in override like the subarus do but you may search the jeep forums. Subarus have a spot in the fuse box you simply place a fuse in to force it to 4wd instead of the AWD. Im sure if this isnt an option you can wire up a circut to fool the computer into 4lo. Of course the other option would be to get a command trak xfer case.
m2rtin
