Heater core bypass/coolant filter
Cracker
N.GA Mountains
Another upgrade complete, finished the install of NAPA coolant filter head and a heater core bypass. I have seen where several have done the bypass with elbows, nipples and tees, FYI: sharkbite 3/4” fitting fit 5/8” heater hose perfectly and looks much cleaner. Also did a custom fabed bracket for the filter head.
Clb
Another old truck
nannyfornia
Just cuts out the heater core so the ac works
Nugget
Colorado
Can you please explain how cutting the flow of coolant to the heater core impacts ac functionality?
Thank you.
captain720
Washington
Thank you.
Things are supposed to not blow hot air when you turn the heat off, but sometimes the solonoid or whatever that makes that happen breaks when it’s old. This is a workaround for that.
Nugget
Colorado
For those interested, the following thread answers my question pretty well.
If anyone has anything to add, please feel free. Thank you.
Basic explanation….
The Heater Core, and A/C Evaporator are inside the same ”2 compartment box” on the firewall. All the air that enters the cabin goes through this box… There is a blend door in there that blocks off the air flow through the heater core (well it’s supposed to) so it only goes through the A/C Evaporator to cool the air. The blend door can break, or the seal can ”leak” allowing hot air into the cool air flow. Just remember, you have 190+ degree coolant running through the heater core whenever the engine is running, wither you are using the heat to not…. Cutting off coolant flow to the heater core, takes that heat load outta the “box” and allows the A/C to cool better, since it is not trying to cool the ambient air, it is also trying to take the heat out the heater core might introduce.
An example of this heating…. If you are running just the vent, (A/C not running) and you start off this way when the engine is cold. You can drive around and the air from the vents should be close to the same temp as ambient. But stop and shut the truck off and go inside (Once up to normal operating temp) and you come back out, and now the vent blows much warmer air that before you stopped. Reason is, the heater core with the hot coolant in it has now heated the box, and the vent is pulling that heat out while running….
Somce vehicles from the factory, I know the Ford Ranger was one, and I think my Excursion may also have one, is an vacuum activated valve that will cut off coolant when the A/C is switched to “MAX”…..
jwsfarrier
Molalla,OR
Thats a clean set-up. Really like the mounting bracket. My coolant filter has just been hanging out on the fender , this gives me motivation to actually mount it and do the heater core by-pass. Thanks!
JFMac
