Heated fuel filter ...
FORDF250HDXLT
Maine & Oklahoma
that's the way id go right there if i ever needed to keep my filters warm but they blend the fuel so they're really just not needed these days.iv got the oem ones bypassed and iv only had trouble one time when i got some water that started to freeze in my filter.since it only happened that one time,i never did put a heater blanket on it.
BDCarrillo
Abilene TX
That's a pretty good heat output on the 3" 100 watt version since the stock heater is closer to 20-30 watts. The 12v option seems like a good idea for improving straight WMO or WVO flow through the filter and into the IP. I may have to try one out!
tbrumm
Richland Center, WI
I have a similar wrap around heater I use on my fuel filter. After I first got the truck, I had trouble with glycerin in the fuel blinding the filter when it got below 10°. Above 10° was no problem. Anyway, the blanket heater kept the truck running no matter how cold it got. I have dropped and thoroughly cleaned the tanks, so residual glycerin coating the inside of the tanks is no longer a problem. With the winter blend diesel and fuel additive, I haven't needed the wrap around filter, but it is nice to have it on there "just in case". Where did that residual glycerin come from you ask? Perhaps the by-product of improperly concocted bio-diesel blends purchased by the Air Force from the lowest bidder!
